There's no part available in that range--use the stocker . The TA balancer is just a hub thats neutral, it comes with the weight for external apps. The 2 mentioned above are press fit and are quality pieces at a price.Don’t want to spend more then $180
For every part on the Chevy just multiply it by 400% and you have the cost for the BuickI'll end up spending the money on a bhj or ati.
I'm not going to use the stock type. I don't think It's a good harmonic dampener.
I'm used to small block Chevys. You could get a decent harmonic dampener for around 150.
The options are limited with these turbo Buicks.
don't be so quick to throw in the towel. Your internal balance crank can still be used for external balance. It just means that a little more metal has to be removed from the throws. Once you bolt on the pan you will never know the difference. Or you can just have your stock balancer and flywheel neutral balanced. Either way its best to end up with a steel forged crank over the cast iron stocker. I have done dozens of forged crank internal balance engines with neutral balance stock parts. Its just not a big deal. Saves a LOT of money in the long run and if you never open the hood no one will ever know!!............RCErnie,
Just wondering what rout you ended up going with this? I just received my "internal balance" forged crank and am in the same boat.
I'm thinking a screwed up and should have gotten the external balance instead, but it's too late now. Actually considering just using the stock crank now since the cost has essentially doubled.
Ernie,
