have 4 ways flashing, no right turn signals .
Yah's 87
this is also on the dash. there is nothing that illuminates when the right hand turn selector is activated. considering and new turn signal selcetor switch. been like this the past few months. Any fuses related to this circuit? thankx.......
was the cluster taken out at one point? it happen to me one time I didn't seat the cluster all the way back in. could here the flasher but no flashing lights in the dash as far as the tail light I would go and check the bulb that's not working and push it in while you have the flashers on .probably just doesn't have enough tension. and check contacts see if there not worn melted ect.
i just installed brand new bulbs , and 4 way flashers work. just not the turn signal for right side. thinking its the switch on the column
