Header to turbo leaking
77tech9
Extreme Huffer
The header to turbo flange keeps leaking and I cannot stop it for nothing.
I've tryed no gasket sanding both sides perfect, leaked on every side.
Tryed to make a paper gasket with red rtv and it just blew out after 10 psi boost.
It had a copper gasket in there when I bought the car that is cracked a bunch and leaks super bad, not sure what I should do.
Napa wont have the paper gasket for a week, and i'm afraid it will just blow out.
Read a post that autozone part #9097 works wonders... anyone tryed this worth a shot?
Autozone shows a felpro exhaust flange gasket with that number. I don't know what it is, but worth a look for $.89.
If I was you I would go to the local PERFORMANCE parts store and inquire to them about a copper header to turbo gasket for your year Turbo Buick. I went to autozone and they had no idea what I was talking about (go figure) I can't remember the name of the company that made my gasket but I got lucky and asked the guy at the counter who owned a GN and he had ordered and extra.
-dan
altho GM no longer stocks the Riviera gasket, NAPA carries the equivalent. It is a graphite gasket, and the ONLY thing that has cured that problem for my car. I'm sorry, I don't have a part# but if you do a search here, you can find the GM part# for the Riv gasket, and NAPA will cross reference it for you. I bought 3 or 4 of them. They had to order it from out of State, but it only took a couple of days. HTH
I have a Riviera gasket on order, but these $.89 ones work GREAT, finally something stopped the leak!
9097 is the part number, they have them at autozone, checker, and advanced auto.
Put a little red high temp on them and it sealed perfectly, we'll see how it holds up!
Originally posted by 49-blues
You could also try a riviera gasket.
As mentioned, Riv gasket is not available through GM. NAPA Riv replacement gasket is G26951........made by Victor. About $3.
