Heater Question!!!
kosonen04
JustA6
I have a 85 GN and for some reasion the heater has stoped blowing air none at all the lights on the dash turn on like it would be ok? but no air on any settings or anything. Is there a fuse for the fan it self or what should i check out someone help me its -4 here in wyoming and its a cold drive to school Thanks
there is a ac fuse and a heater fuse also if you dont have any lights check the courtasy fuse.
Alright i looked at the A/C fuse looks good but cant find a heater fuse cant find a slot for one? what else could be the problem i have all my dash lights and everything but no fan comes on.
heater fan
maybe the heater motor is shot---run a wire from battery to the wires on the fan connection see if it runs --if it does you have power loss somewhere
check the connector by the fan outside under the hood by the antenna it is a plug .it is known to over heat and corrode
