heater valve ?
#2
Lee I am running mine wide open into the heater core. I don’t have ac though. I think you need a bypass if you use a gn valve. I’ve read that you need to maintain flow and if the valve closes it will deadhead. I haven’t confirmed this though.
#3
Thanks for your reply--I bought a generic valve--hooked it up without a vacuum canister--yet to start car--never heard of having to have some flow. Back in the DAY a person could put a post up in the AM and have multipule replies by PM. --Lee
#6
Look at the 3rd gen camaro heater valve. It has 4 ports and is vacuum actuated. The two ports off the water pump have to loop, the 4 port valve allows this when closed (and opened as well).
#9
Lee,
I'm not sure how old this thread is (the recent website changes etc have me more confused than usual) and you might not need another answer to your question but I did an LS3 conversion into a worn out LC2 Turbo Regal and used the factory HVAC system except for the compressor. I do have the heater core valve in place and everything works as it did originally. A/C is cold and the heater is hot.
