I have a surge at wide open throttle. I have an 87 GN. Stock turbo and intercooler. Usual mods- 17 lb 93 octane chip from poston ( I also tried an older Kenne belle 93 oct. 17 lb chip too), adjustable wastegate and regulator-set at 42 with line off, Reds fuel pump, Kirbans 30 lb injectors,No cat with Hooker exhaust, K&N cone, I have put on BRAND NEW coil pack( 2nd one) , module, 02 sensor, fuel filter, AC R43ts plugs, boost sol., wires, IAC sol. , billet vac. block, I have cleaned the throttle body and intercooler. I had this surge before I did most of this work. My fuel pressure goes to 55 lbs at wot and my boost guage needle goes to 16 lbs. I noticed this morning on my way to work when I punched it the boost guage went to 18 or 19 for a second then stayed at 16. It is not a constant surge but it is bucking BUT ONLY WHEN I'M ON IT. On my friends OTC last week we had 900 something on the 02 and we got at one point 6 degrees of knock. I just changed the wastegate out last night . it had a stock one on it and the boost was 13 lbs. It's holding 18 lbs of vac. . I checked the TPS last night and it's .42 and 4.6 wot. I have only had this GN for a month and I bought it NOT running. I changed the crank sensor coil pack and module before I found out the CCCI fuse was blown. Then it started up. I have rapped on the MAF and the idle did not change. This surge has got me going nuts. Can someone give me some examples of some things that will cause a surge at WOT. I checked the wastegate lines and they look fine
