t3intercooled
- Jul 20, 2004
All I need to do is put my intake on then drop the motor in the car. I seriously need some help. My intake gasket is not lining up correctly. It seemed like the bolts were rubbing on themanifold so i drilled the bolt holes on the manifold one size bigger, and still having a problem. Its as if the gasket holes are not drilled at an angle causeing it to bind up. Any ideas on what I can do has anyone had any problems like this before?
Brandon
Brandon
