Are you referring to this as your No Start Tree ..
http://www.vortexbuicks-etc.com/troubshootgeneral.htm
84-85 or 86-87?
This has definitely happened to nearly everyone on the board by now!
Grounds are very important but I dont think that is your problem in this case.
I went to AutoZone and purchased the noid light kit to see if my injectors were firing. I had no spark and no injector pulses. I pinned it down to my crank sensor and purchased another one. It has to be set just right with plastic feeler gauges. Turned the key and fired right up. Thanks to a friendly turbo neighbor ( Mike McCoy) for allowing me to used a good known coil pack to aid in troubleshooting. If you rebuilt your motor and put the crank hub back on, then remounted the crank sensor chances are you could have sheared the edge of the crank sensor with one of the spaces ( windows) on the crank hub on the first engine rotation. Out of curiosity, how are you checking crank sensor voltage while you are trying to crank the car, I think that is a pulsed signal with a reference for #1 cylinder.
Orange ECM wire at the battery connected?
Report back with findings please.
