Buickcruiser
- Mar 10, 2004
I have been down in my garage all day working on my 84 GN. My passenger side head gasket is seeping water into the oil. I did a compression check and all cylinders were 145 except the rear dr side cylinder was 120. I removed all head bolts, exhaust header bolts, power steering pump, rocker arms, and the intake manifold bolts on the dr. side. I know that after all of the years the gaskets will stick the heads on these cars. I don’t want to start prying on the head and risk damaging my head. I am pretty sure I got all of the bolts to remove the head. So do you guys have any ideas.
David
David
