help knock
CHANCE
No longer a Buick guy!!!!!!!!!!!!!
hey guys my scanmaster showing is showing 3.0 degrees of knock with alky its this ok or should i worry
I'm sure anyone who could answer your question will want more info...like when the knock occurs, etc.
But for now make sure the alky is actually working, and make sure you have it set to start spraying early enough to protect against knock under boost.
I'd say it's something to "worry" about, expensive alky kits aren't supposed to leave you with knock.
Ok here it gos sometimes i get knock sometimes i dont im running 87 octane with straight meth being injected.
The alky kit works checked that.
Only 15 PSI of boost.
I might be getting it when i shift
