well i have tried to search and couldnt find similar situation,seems more problems were bad spool
my spool up is fine , just wont kick past 10lbs
i have tried 3 sol, 2 actuators
all stock stuff here
i guess possible both were bad,but not sure
i have tried shortening rod,no change, plumbing straight from turbo to actuator,no change, new lines,
first i found blown ecm fuse,helped spool, fixed up a small header leak, spools even better, just the max boost
i have a cat, but i am assuming a clogged cat would yeild some bad spool up also, what do ya think
any help would be appreciated
Chris Pacheco
Chris Pacheco
