Help Me Pick Next Mod
390STEVE
PROUD AMERICAN
List of mods so far. what next?
Kirban, fuel pressure regulator
CAS V4 intercooler
PTE-51 polished
Walbro fuel pump
ATR downpipe
Catback exhaust aerochamber
SMC alky kit
Bruce T. PTS Killer/Street tranny
PTS 9/11 3000 stall
MSD 50 injectors
Eaton posi
Boost controller BSTC
Scanmaster
Cold air intake "big mouth"
ATR 1 3/8 sway bar
Belltech 2" drop spindles
B&M tranny cooler
Power plate
255-50-16 mt et street radials
Thanks Steve from Minnesota
CAS V4 intercooler
PTE-51 polished
Walbro fuel pump
ATR downpipe
SMC alky kit
PTS 9/11 3000 stall
MSD 50 injectors
Eaton posi
Scanmaster
ATR 1 3/8 sway bar
B&M tranny cooler
Power plate
1/4 mile time slip should be the next mod :D ..
1/4
Just bough car. going to Track June 21 Wed. night race. will post numbers then.
Sweet combo !!!!!! Looks like you are well on your way. Maybe a Direct Scan?
Anyone wanna chime in to guess how quick it will go? I'll say 11.92 :cool:
Good luck !!!!
chip is
The chip is a Joe Lubrant from PTE, Precision Turbo and Engine. Timing is set at a modest 20
Get some more timing and boost to it :biggrin:
If the car has the original valve springs, i would put new ones in if the car doesnt pull on the top end.
BW
Yes, the Direct Scan is a tuning aid that gives you a little more data and the ability to replay your runs in several playback formats. You already have a scan tool, but the Direct Scan will allow you to replay and share data with others.
Just run what you have and enjoy !!!!! Maybe add a knock gauge like the one from Caspers.
Almost the same Combo
My car just about has the same combo. with 140,000mi My dyno numbers are below. Cam & Heads are out of the question. The motor has never been opened.
If your installing the valve springs yourself, be carefull I know a bunch of people that have wiped a lobe on there cam from messing up the valve spring install......just letting you know.
Just wandering how can you mess up on valve spring install. Maybe if you install the wrong springs? :confused:
Valve Springs
Thanks for the concern on valve springs but they are aready done, so is the timing chain.
I was told by previous owner of car I should put on a pt54 turbo
I sure Frank new what he is talking about, but will this work with current combo? or would I be beter off leaving turbo alone and doing something else.
THANKS
STEVE
How Fast
how fast?? very good question. I would love 10's but if I do that what can I expect for problems with lower end of engine? Also would I be better off install a bigger turbo or going the head cam route?
turbo cost $500-$1000
ported heads and cam cost??
Thanks Steve
