- Feb 14, 2002
I just finished up the install of my new engine and I must've screwed up something in the wiring harness cuz the fuel pump will not run when I key on. I can manually get it to run by jumping power to the test connector, so it seems to have a good ground, just no power. The injectors will not fire either.
Any ideas what might be wrong??
I checked the harness grounds at the back of the pass. side cyl head and I checked the power leads at the starter and they look OK. There are only 2 power leads at the starter going to the harness, right?
ground to firewall seems OK.
FP/INJ fuse is OK, and the fuse block is showing 12 volts on that circuit.
Swapped relays - didn't help.
If anyone knows where the fuel pump and injectors get power from that might help me out here.
The only thing not hooked up yet is the powermaster brakes.
