Help no spark
RandyWallace1
4
0
1
49
first I changed plugs and wires and still running rough, decided to change oil and filter and coil pack. Car fired right up and then died, won't start and no spark. Put back old coil pack stlll no spark.
Reapersgbodys
206
86
28
50
I would start looking at wiring diagrams, also check fusible links at the starter, ground for cci
bpman1234
1,801
95
48
south florida
check the wire's inside the coil's makes sure there not pinching with the case when you put it togther with the module or other .wires.
turbo nasty
Turbo Dojo / MNTR
Jul 19, 2001
8,178
411
83
St Paul, MN
Disconnect wiring from module (1/4" nut driver).....replace fuse. If fuse doesnt blow...its the module. If it blows....its wiring
Top Bottom
