help with tranlator
cutt
installed the 3.5maf with translator,but got a maf code.did i do something wrong?
Try resetting the ECM (orange wire by battery unplug the clip wait, then plug back in). If not are the settings correct inside the Translator?
Here's a link.
Translator Settings
translator
seems as if i have everything right,im running a regular chip so i have the third switch up.also the maf was used so it could be bad.
translator
anybody else?i tried a different maf and trans but still got the check engine light so it must be something im doing wrong.
It is possible to get the smaller plugs inserted backwards if they are forced.
Please recheck them.
The switches in the translator need to be
On On On Off (regular chip)
Set the dials: 0 0
Inside the translator make sure no components got smoked if plugs were inserted backwards.
Bob
