tim87tr
Obsession or Digression?
- Sep 19, 2001
Trying to figure out why this is not working, any ideas?
Per gnttype, I spliced into the green wire with yellow stripe that runs into the high speed relay (front driver side), and ran it into a switch and other side into a ground. Ground is working since I am using the same one for a line lock light.
For the fan switch I am using a 3 pole lighted switch, and the light is on when I flip the switch, meaning there is a connection, but fan does not come on.
Did I splice into the wrong wire? I didn't think I did since it mentions the same wire goes to temp switch connnector on the intake manifold, and that is the same wire.
