I have finally fixed my high blm problems (cracked header repaired) and vacuum leaks fixed. Now I am plagued with high 02's and kr at about 4-6 degrees. i ahave tried turning down the fuel pressure from 43 static to about 39-40 psi to no avail. my blms are right around the 126-128 mark with the fuel pressure set to the lower static setting (38-39psi). The car does not break the tires loose or chirp the tires for that matter. what gives???
I was thinking of replacing the 20 year old tired stock injectors. could they be what is holding the car back and could new injectors get my o2's and Knock in line?
scanmaster #'s
blm=126-128 @ idle/will go down to 118-119 with higher static fuel pressure
coolant=187
cc=0-251
volts=13.2-13.8
tps=.44
iac=21
maf=5-6grams
o2's @ idle fluctuating above & below .45 (as high as .750 something)
Car is all stock and that includes turbo and torque converter.
-brake torqued the car to check stall speed and tires begin to overcome brakes at about 2300 rpm @ about 5lbs of boost
scanmaster #'s
coolant=187
cc=0-251
volts=13.2-13.8
tps=.44
iac=21
maf=5-6grams
