found this a while back , forgot where it came from
Weight savings:
PLEASE BE CAREFUL WHEN PURCHASING AFTER MARKET EQUIPMENT. SOME PARTS MAY BE HEAVIER THEN OEM EQUIPMENT. For example, I bought some aftermarket OEM rotors that were 1lb heavier then my stock rotors. IF you are concerned about weight, ask the weight before you buy.
front bumper reinforcement (87 GN only):
steel = 64.5; aluminum = 45.8; savings = 18.7 lbs
Bumper Export Braces:
(export brace replaces inner bumpers support)
Chrome steel bumper with small steel export brace, no lights installed = 33.5 LBS
Front steel chrom bumper with only the export brace attachments, minus the center piece, no bumperettes, but does have the full length black strip = 26.5 LBS
rear bumper reinforcement (87 GN only):
steel = 69.5; aluminum = 48; savings = 21.5 lbs
rear brake drums:
steel = 10 lbs; aluminum = 5 lbs; total savings =10 lbs
front sway bar:
stock solid = 30 lbs; 1LE F-body hollow 20 lbs = ; savings = 10 lbs
front rotors:
stock 17.5 lbs = ; aftermarket @9.5 lbs (SSBC) = ; total savings = 17 lbs
front calipers:
stock = 6.75 lbs; aftermarket = @3.25 lbs (SSBC); total savings = 7 lbs
aluminum radiator support:
steel = 30; aluminum = 13; savings = 17lbs
door crash bars:
savings = 38 lbs
sound deadening material underneath and behind rear seat:
savings = 10 lbs
RJC pulley set:
stock = 10.5 lbs ; RJC = 3 lbs; savings = 7.5 lbs
Rims:
steel = 29 lbs; aluminum = @19 lbs (depends); total savings = 40 lbs
Centerline Auto Drags
15x10= 19lbs
15x8= 17lbs
Spare tire:
35 lbs
Jack:
15 lbs
Mini starter:
stock = 18.5 lbs; mini = @8.5 lbs (turbobuicks.com); savings = 10 lbs
Fiberglass hood:
stock = 55 lbs; fiberglass = 28 lbs; savings = 27 lbs
Fiberglass decklid:
stock = 60 lbs ; fiberglass = 23 lbs; savings = 37 lbs
a-arms
stock = 9.5lbs ea ; aftermarket tubular (UB Machine) = 4.5 lbs ea; total savings = 10 lbs
AC Compressor: 14 1/2 lbs
Core: 6 lbs
Lines: 3 1/2 lbs
Condenser Can: 1 lb
25 lbs total weight loss.
Stock IC with duttweiller neck: 15 1/2 lbs
Dequick V2 front mount, no pipes: 28 lbs
Conveters:
Precision 9.5 lock up (one quart fluid in it)= 37 lbs
Precision 9.5 non lock up (one quart fluid)= 29 lbs
Stock D5=41 pounds dry
9/11 convertor = 36 LBS DRY
other things and still appear totally stock
HP plastic headlamps
eliminate cruise if you have it ,
remove insulation on qtrpanels, behind trim
seat belts -eliminate rears , get front shortened and fixed to pilar mount for you and eliminate tensioner /retractor assemblies
drain washer fluid bucket (remove wiper motor and arms for track use)
remove rear veiw mirroe and passenger visor (dont worry once they get behind you thats where they'll stay )
