Well the kit that I got from jegs, same as summit, only came with the aerochamber mufflers, which I like ALOT. If you are planning on running a cut-out then don't worry about it. If you plan to run through the exhaust and plan to get pretty fast, then go ahead and upgrade before you put the exhaust on.
