tony taylor
- Oct 12, 2003
Hello guys,
I have an 84 hot air with a 33 turbo, 36# injectors, Lee Thompson 3"DP, 2 1/2" up pipe, 30 over block, built bottom end with Diamond forged pistons, ported and polished heads, 3 angle valve job, 212/218 cam, Lee Thompson built trans with 3300 stall, and a 1987 computer with 26 degree timing in 1st and 2nd gear, 23 degrees of timing in 3rd and OD. I want to spray 80-100 shot of NOS after the turbo. I run 116 octane in the car.
I plan to run 23-25 pounds of boost off the bottle.
I would like to know what is a safe boost number to run on the bottle?
Do I have too much timing?
On an old setup, all stock except for drag chip, I ran an 80 shot before the turbo and on 110 octane at 17 pounds of boost with no issues.
I would appreciate any advice...
Thanks,
Tony
NOS4LYF
Thanks,
Tony
NOS4LYF
