turbojitsu85
- Aug 23, 2002
I have a few things still from when the car was a hotair. First fifty dollars takes it. Everything worked before I broke the engine.
crank and water pump pulley
fan blades
crank sensor
black metal vacuum lines
module/coil bracketmetal coolant lines with heatshield
thermostat housing
stock maf pipe
dipstick and tube
trans dipstick and tube
throttle cable and brackets
cruise cable
trans cable
fuel lines - the ones with the pressfitted rubber hoses on them
egr stuff
power steering pump with lines
rad hoses
fan blades
crank sensor
thermostat housing
stock maf pipe
dipstick and tube
cruise cable
trans cable
egr stuff
rad hoses
