I can send you the tlink file if needed, but what I'm seeing on the beginning of my "tuning" mission is that my iac counts are high.
I set the iac per red's method (set idle speed at 650 with iac disconnected). IAC plugged in and car idles fine and isn't stalling or suffering from a stumble.
Should I focus on getting those numbers lower, or is this trivial?
Specifically, the warm idle in gear gives me iac counts of 50-52 or 20-22%. Int and Blms appear ok. Before I start going into the wot tunes, I wanted to make sure the basics are correct.
What do you think?
What do you think?
