2 wooden dowels for handles, 2 eye bolts, 1 length of guitar string, and 2 people use a soldering iron to melt a hole through from the inside stick guitar string in and tie it to both handles, and start sawing away. make sure to pull with the cut. you want that string V-shaped when your cutting. make a T handle with the eye bolts. make sure they have wood threads
you do not need to remove the dash, but remove the top dash peice, remove the pillar trim and remove the trim peice that holds the headliner in. use a peice of sheet metal or aluminum to protect the dash from the wire and move it along the dash for protection.
