How does the Timing Chain get oiled?
1QWIK6
Torque wins
I keep snapping timing chains... I think it may be in part to low oiling... How does the stock T/C get it's oil?
The front cam bearing is the first place to get oil inside the motor. As the oil leaves the bearing surface it has two places to go. One is into the cam galley area under the intake. The other is directly on to the back of the cam gear of the timing set.
