how many things can you think of to lighten up a GN
87grandnat
i am considering putting the GN on a diet, i know a couple of ways to lose weight, but thought i would see how many other things you can do to shred some weight off, thanks
#1)Aluminium Driveshaft
#2)Aluminium Front and rear bumber supports
#3)Fiberglass bumpers
#4)Fiberglass hood, fenders, doors, trunk lid.
#5)Lexan windshields and windows,
#6)Remove Ac box completely or install heater box.
#7) Aluminium Front support
#8) Aluminium radaitor
#9) Convert to vacuum Brakes
#10) Mini starter
#11) Convert transmission to powerglide or turbo 350
#12) Aluminium Wheels or Magnisum Wheels
#13) Remove interior like the Ricer:D
#14) mini tubb or full tubb the back end
#15 convert to a fuel cell
#16) Convert rear drums to disc brakes
#18) U go on a diet;) :D :)
I think thats most of it:p
You can pull the foam insulation crap off the back sides of the carpet. That'll net you ~10 lbs.
If your car was undercoated, remove the undercoating. Its a long, difficult, nasty job, but it will net you ~100lbs AND you won't have to worry about getting that nasty crap on you when you work under the car anymore. Cleaning the undercarriage is a cinch too - Krylon flat black.
Aluminum wheels, drums, bumper brackets, core support, plastic headlights, remove spare & jack, floor mats, power antenna, power windows, power locks.
Take out all of your power options and put in manual stuff.....no radio or speakers......remove front sway bar...no hood shocks or hinges, just hood pins & keep a stick with ya;)....remove your spare tire and jack....fuel cell.......battery in the trunk(not really saving weight....reminds me you guys see the saturns now have their battery in the trunk)........once you take off all of this stuff then you can throw a huge roll bar in there.......;)
Aluminum: pulleys, Vega manual sterring box, shocks, oil pan, trans pan, rear end cover, 9" rear carrier, ...9" converter, odyssey battery, hollow sway bar, skinny rims up front, bench seat or racing bucket seats....
