May 30, 2004 #1 N NEARING Active Member Joined Apr 9, 2002 Messages 1,822 How much air do most of you run in them? Thanks.
Jun 1, 2004 #2 T turbofrank Well-Known Member Joined Nov 4, 2002 Messages 2,481 I use one only pass side. 15lbs at track 7lbs on street
Jun 1, 2004 #3 C charlloots SMO-CUM Joined Aug 1, 2002 Messages 712 17 psi passenger side 12 driver side
Jun 1, 2004 #4 W wbrophy Member Joined Dec 2, 2003 Messages 629 With that much power I would try 30 and 5 at the track. See if the car comes out level, if not then adjust.
