How much boost?
oehm
How much boost can you run through a stock 87 TR (with proper injectors, and fuel pump of course) only using 100 octane unleaded gas, and no alky, or propane?
Every car will be different. If you're looking for ballpark, I will go out on a limb and say 20 psi shouldn't be a problem. It will depend on the timing of your chip too. A 22° degree chip would be good for 100 octane I would imagine, and 20 psi should be reachable. But as I always say, 'get a scantool'! Good luck :cool:
