Here's some info on spring pressure I posted a while back. I would say do the springs if they have never been done. BUT! like advised above stay away from the high lb spring pressure, no need to stress the stock cam. Do the springs, 3" dp, good flowing stock location I/C, and turn that 60 up! You have a mid to low 11 sec combo!
These numbers are from a 1996 issuse of GSX-TRA. Test was done at recommended installed height of 1.71. Note GM recommends a minimum seat pressure of 78 psi.
Spring Type:
New stock GM...........................78-81 psi
New Comp Cam (979)...............86-88 psi
Stock w/30kmi. (raced often)....45-52 psi
Stock w/32k mi. (daily driver)....55-61 psi
Stock w/62k mi. (raced Often)...44-51 psi
Stock w/65k ( daily driver).........49-58 psi
stock w/98k mi. (daily driver).....45-56 psi
stock w/68k mi (overheated).....41-48 psi
Comp Cam w/34k mi (979's) .....74-80 psi
Test results were on all springs and these numbers were the range that was found. You can see that even a low mile car in 1996 sping pressure was down. I just recently changed the springs in mine, top end feels more peppy to me. These numbers anwsered the question for me.
