how,s your ESU
jlat
hello peoples: I think most of us use a stock ECU. What would a non stock 1 do 4 U. Not just a replacement of the stock 1 .
IBBY
Aftermarket ECU’s allow you to tune out any performance or drivability issues that a stock ECU might not be flexible enough to address. You can change hardware like injectors or ignition system and simply make a change in the tune to support the new hardware. And aftermarket ECU’s provide engine protection features that keep the engine safe by shutting it off in case something goes wrong at wide open throttle, such as loss of fuel pressure, lean air/fuel, over boost, loss of crank signal, etc
You need a knowledgeable tuner to make it work. Or you need to get really interested in learning all about it and maybe take a few lumps along the way to do it yourself.
IBBY
You're not jlat. He has over 3,000 posts and none of them were this poorly typed. Reported.
hello peoples: What do youz think is a computer Ai. Seems like w/the ESU it deals with alot and then deals W it. Puters R pretty amazing just like cell phones. I have a cell and just started asking it questions. Pretty kool.
may the ECU B with U
IBBY
