How tight with the camshaft?
counterman
In doing my mock up, I noticed that the camshaft will turn by hand in the new camshaft bearings, but with some effort. I tried both the original cam and the new Edelbrock unit in the block, and both have some drag. Of course, the new unused cam is a little tighter. How tight is too tight? Thanks, Counterman.
It should turn freely. I think .002" clearance is the spec. Problem could be bearings installed incorrectly (crooked, raised metal from install), incorrect bearing wall thickness or journal bores out of alignment.
TOO tight
It MUST turn with 0 drag---More importantly check it once the main caps and heads have been torqued down. Twice I have had one of the 2 center cam bearings to spin once the eng. began to build heat. There is not as much material surrounding the 2 center bearings as the 2 end ones. Torquing the heads and main --you are pulling in 3 different directions and it CAN oblong the cam bore making the cam journal TIGHT.
If you can turn it by hand without much effort, it is ok. Generally speaking, 9 out of 10 times a cam is hard to turn, it is bent. Brand new cams come out of the box like this sometimes. Most competent machinists can straighten it on a v-block with a press.
