Any way to know when fuel pressure is set to the right value? I have a 87 GN with an aftermarket turbo not sure of the size but bigger than stock of course, champion iron heads, headers, 42lb injectors, k and n intake, fuel pump, adjustable regulator, I'm thinking th car is running rich as it doesn't have the power I think it should, what should this combo run at the track has 3:42 gears, anyways is there a safe way to get the fuel pressure in the ballpark of where it should be without damaging anything thanks!
