Took the car out to tune & only get 14 psi boost. Yesterday boost was set at 22psi.
Turned the wg actuator in up to 6 turns & only get up to 15 psi.
Opened a bleed valve & boost goes up again, so am thinking the WG selenoid is not working.
How do you test the selenoid.
Its closed ( cant blow through )with car running or not, wires connected or not.
Can power be supplied to open valve ?
What current should be being fed into the selenoid ?
This may be the time to go to a grainger valve style boost control setup.
