SignUp Now!John Larkin said:Casper's tester only tests the coil pack. Module testing needs to be done at a parts store like Autozone. They have Wells module testing machines at the ones I've been. It's accurate and free.
rob86gn said:I only suspected the Wells module since I have been thru 2 Wells coils in a very short time period. I recently ordered GM coil, GM module, and Taylor Thundervolt 50 wires TAY-98024 (custom for GN).
The wires are spiral core not solid core, I think that may have been a contributing factor too with my situation(solid core wires). I spoke with a GN guys at a car show in Sycamore, IL today and they said they would not buy a Wells coil or module.
I am using a Wells crank sensor though and that seems to work ok, at least something does...
Red Regal T said:There's no way to test them except on your car.
Hang in there folks.
I've got a module tester in the pipeline, soon to be released. Mainly, it's for diagosing ignition problems, no-start conditions, bad wiring and so on.
It's a hand-held unit that will test each and every wire on the coil module, with a "go-no go" system so it will be able to check the cam sensor, crank sensor, and all handshake signals to the ECM. It will be able to diagnose an absense of cam and crank signal, check for power in the appropriate places, and have a cam sensor "override" button that will start a stranded vehicle along with a built-in tach.
Well at least it's in the pipeline. Soon....
