Hydraulic Roller Vs Flat Tappet
Mad_Trbo
Ok - trying to do my part and I have been reading up on the hydraulic vs the flat tappet. I can definitely see the benefit with the reduction of friction and the ability to change the profile on the cam lobe. Thus allowing for a difference in duration without risk to the cam itself and the potential of the tappet style ??? lifter ???? grinding into the cam.
My question is, what makes it a hydraulic set up. I have been trying to find a picture example of the differences between the two. The only thing I have seen is the mechanical unit that rests on the cam lobe has a roller vs a simple flat piece of metal. I imagine this still comes in contact with some sort of pushrod which then contacts the rocker mechanism which activates the valve. Would this be true?
Segway to the next question. I have seen some pretty trick rockers which look like they also incorporate a roller mechanism. Is this part of the whole switch to the hyrdraulic set up or can you go to roller rocker arms without making any other changes?
