I just rebuilt my 200-4R. I have a complete PTS pressure regulator system and a PTS deep pan.
At 1000 rpm Park:
No TV: 100 PSI
Full TV: 260 PSI with a +/- 10 PSI shake on the needle.
The pressure comes up nicely and fast as I pull the TV cable but as the needle climbs the shaking increases.
It shakes the most when I pull hard on the TV cable.
Now here's the thing: if I raise the RPM to 2 - 3 - 5 - 5000 rpm, at full TV the pressure drops! And stays stable at 160 PSI. Less shaking at high rpm.
At 800 rpm the needle climbs above 260 PSI.
First I thought it was the oil level. I added a couple of quarts... no difference.
Then I thought it might be that the PTS oil pickup was sucking air. I visually checked the pickup assembly for holes but did not see any. Then I replaced two new seals... no difference.
What would it be? A hole in the pickup maybe? But the pressure reads stable at 150 on throttle.
The remaining options: something in the VB or the pump.
The trans shifts fairly ok when driving. But the pressure never goes over 160 since there is always some throttle.
I'd rather check the VB first before I pull the trans to get to the pump. But where should I look?
Can the pump be rulled out? Or can it be it becomes inefficient at high rpm? Could it be the pressure regulator? I had the pump rerbuilt (in Belgium) last year.
D
At 1000 rpm Park:
No TV: 100 PSI
