The last couple of weeks my car has been getting worse and worse with gas mileage and now recently, it's idle is the pits. It has thrown numerous Code 45's at me. I ran T-Link on it around town, and the BLM's most of the time are bottoming out at 105 quite fast. Bucking and stumbling are there too. So far these are the things I have tried to get this problem fixed:
1) Did a leak down test of my injectors and check valve on fuel pump, holds full pressure for hours after car is shut off.
2) Replaced my O2 sensor (actually tried two of them). Counts are kind of on the low side once in awhile, but for the most part, it seems like it is reacting fine.
3) Tps sensor. All settings and voltages read as they should.
4) Sprayed all vacuum lines and their junctions to try and find any leaks, so far I have found nothing.
5) Did the old MAF tests. Tap in and the car stumbles. Disconnect and the car wants to stall, so I think it is working fine. All GPS number s are fine on T-Link.
6) Checked EGR valve. Cleaned it and did a vacuum test on it and the lines. All is good.
7) For kicks I took my Power Plate out. Nothing changed but for some strange reason, the car is spooling faster........
8) Replaced the fuel filter.
9) Replaced the PCV valve.
When I take the car for a WOT run, the BLM's are at 119 (good) and the car knocks abit with tons of timing being pulled out.
The only other thing I can think of is that I have discovered a header crack on the driver's side. But I can not see this affecting the state of the car at idle so much. I doubt that this crack popped up within the last two weeks. BLM's are at the bottom of the barrel at idle and it is usually so rich, my eyes start burning. The car has a Conley 92? chip in it, but I have tried two other chips with no improvements in performance.
Sorry to go on babbling, but I have reached the end of my rope. I am going to get the header welded (hopefully this week), but I still don't think that this is the cause of all my problems.
If anyone has any ideas, they would be greatly appreciated..................excuse me while I go in the corner and cry now...........
