Vendor Defendor
Out the window
- Nov 25, 2002
Well, I don’t know whets going on here, but this is what my car is doing:
1. the speedometer quit working while on my way home from getting gas (ha, maybe I got bad gas... that could sound wrong) but the Speedo quit working, but the odometer kept working, so I figured it had to be something in the dash, then the next mourning it (the odometer) quit working too. So I guess I am going to need a new gear in my tranny?
2. car is idling really high, ~1000 on scan master, +/- 50 rpm's I don’t know why, IAC is a little high, not to high, but it sits around 42 @ idle, and TPS is .46 @ idle.. I know those numbers are a little high, but not to bad....
3. Scan master is going nuts with knock. I am not in boost, just cruising down the highway and the knock counts on scan master go crazy. I see numbers ranging from 0.7 all the way to 20+ of KR; I am not in boost, just cruising around. I have no idea what this is about.... maybe a bad ground somewhere... this started around the same time that my Speedo died.
4. on the highway, my car seems to be running a little then higher RPM's, around, well hell, my speedo doesn’t work, so I don’t know, maybe 65-70ish, I seem to be right around 2000rpms +/- 100rpms, I just don’t ever remember them being that high, it almost feels that the torque converter isn’t locking up, I tried flipping my manual lock-up switch, but seems that nothing happened. Maybe a bad solenoid? Btw, if it matters I have 255/60/15's on the back.
Why does everything seem to happen at once?
Thanks for any input, much appreciated.
