Richard,
Thanks for the response.
I have Eric Marshall doing a new chip for me. He has also mentioned the 009s idling issues as well and thinks he might have a fix for that.
We are working on the tip-in stumble issue. He has some code in there for the MAF readings.
The engine is a 6k rebuild. Good quality rebuild from the previous owner. I am just trying to get the bugs out before I put real gas and or propane, alchy, etc to really go fast.
Yes the idle has seem to get worse in last couple of weeks. I have taken the car off the road until I find out what the deal is. The idle basically sucks if you put it to specs. I did find the MAT sensor reading 72 all of time after I found a MALF code for low temp. Cleaned the connections and it seem to do better and read correctly, but still idles like crap. I am going to take the IAC out completely so I can inspect it.
After fooling with car yesterday, it seems I was able to lean it out a bit so it is not pig rich at idle anymore.
The only reason I was thinking MAF; is that I did a WOT blast yesterday and MAF reading did not get above 180. This was at 15 psi boost at 4900 RPM.
Go figure...I'll know more when the new chip gets here.
I like the idea about .38 on the TPS and adjust it to .44. Can I assume some first hand experience here??
Would love to go to 50s right now!! You have some??
