Idle fluctuates when I turn the A/C on
AirBuick
My car idles fine when not running the A/C; the minute I turn it on I get surging, almost stalling and just general idle all over the place. Any ideas as to cause? Got good BLM's at idle ~123.
Thanks.
Is the IAC properly set? Maybe the IAC is bad or the IAC passage is obstructed.
Check for vac leaks. I had a leak last month, but it ran fine until I turned on the AC. It started to jump a bit.
Scottyb:
What vacuum leak did you find? Does the increased load on the motor from running A/C flare up a small vac. leak?
