OneLethal87GN
R.I.P. Lethal GN
- May 26, 2001
When I first start the car it revs up around 1500-2000 rpms. After a few seconds it settles down under 1,000. After revving it up a little or just letting it idle for a minute or so the idle will die down eventually causing the engine to shut off. I was watching my IAC counts before it shut off and they were in the 30s range. I haven't had time to play with the car since having the engine rebuilt so I haven't gotten it up to operating temp. yet to set the IAC counts. My boost gauge shows very good vacuum so a big leak doesn't seem to be the problem. By the way, it did this before the engine was taken out and rebuilt and I did replace the IAC valve with a brand new one.
