Well there are several things you can "try" as tests.
1. One gallon of xylene to 4 gallons gas, no not to make more octane but to help clean the stock inj.
2. Fuel pressure gauge on the wiper blade to look for problems from static pressure to boost pressure.
Prolly not the problem but should be checked out.
3. Professionally clean and flow the stockers at which I would simply upgrade them to new ones. Yeah $$$.
4. Add a Power Plate, might want to consider having the throttle body mods. from Jay Jackson done at this time also too. Yeah more $$$.
5. Alky injection covers up a lot too.
6. Top engine clean might help if carbon is built up in the motor much cheaper to do as a test.
7. Try to find some 94 Sunoco or change brands of 93 gas to see if it goes down or away.
Not sure of your financial situation but throwing money at my car has always worked eventually.
