Ignition Coils-Anything etter than OEM?
Mustang 1
Hello again! As usual thanks in advance for all replies! Is there anyone who makes a better ignition coil for our turbo Buicks? I had a modified 5.o Mustang with a Powerdyne Supercharger with 12psi of boost. The car started popping back through the intake at high boost and it ended being the coil. After replacing the coil with a Mallory coil designed specifically for a Supercharged application the car ran better than it ever had! The coil worked wonders! I have replaced the factory coil several times on my GN for the same reasons. Doe's anyone make a coil designed for turbo application with higher than stock boost levels.ore voltage and saturation? My car would seem to need it at times-so to speak. Thanks again
I just bought one from Caspers, he said it puts out about 12% more spark than a good oem one. Seems to work well on my car.
I know ACCEL makes a hopped up replacement I even think it is yellow. Suppose to put out more juice.
the accel one is black...works fine on my car. Better? can't really say.
Thanks all for your replies. I think that I will look into the Accell coil.Have agreat day!
My coil pack went out yesterday & I had a type II on hand. So far it idles smoother, but I have no track times, yet.
