ignition module to coil pack connections
Dan Thompson
I have the Yellow, Green, blueblack ignition modules wires connected to the 4,2,6 side of the coil.
I noticed that the coil could easily be turned over so the connection would be Yellow, Green, blueblack ignition modules wires connected to the 1,5,3 side of the coil.
Then I made a fatual mistake and started thinking well this is a Wasted Spark Ignition System so what difference does it make.
So the question - does it make any difference and which one is correct?
TIA
I have the answer.
Since the ignition module has the cable connector to the ECM and faces the DS and the coil pack has the EVEN number coil plugs face the front of the car it becomes a no-brainer.
