SouthernCal GN
I come in peace....AK AK
- Mar 18, 2004
Ok- set the engine to TDC, and removed/replaced the cam. Got it all back together, and did the break-in. Started fine, ran the break-in for about 30 minutes, then shut her down. Changed the oil and filter, and called it a night.
Yesterday- the car wouldn't start. Checked the cam sensor- looked ok. Pulled #1 plug and DS valve cover to verify TDC- all looked in order. Crank sensor- same. Finally got her to start, with hesitation, bucking, and backfiring- almost no idle, and runs rough above 1500 rpm.
Shut everything down in frustration, and called it a night.
Questions:
a) can the cam be installed 180 out? If possible, it wouldn't run, correct?
b) getting spark (it wants to run, but acts the same as if a distributor was WAY out.)- #1 plug is sooty and black (but not wet). Any clue?
c) Swapped cam sensor caps/coil pack w/module- still the same.
Any help is greatly appreciated. Thanks!
Questions:
