Info on GTA wheels
justabuickv6
907
0
16
50
League City, Texas
Visit site
Info on GTA wheels
Does anyone know a lot about the 87-92 GTA wheels?
There are obvious differences. IE with or without the dimples.
Does the dimples signify early or late model? Or where there two manufacturers?
GNTurbo6
Asian guy in redneck car
Aug 20, 2006
337
0
16
34
Amherst, MA
I got a few questions about the GTA wheels as well. What are the skinniest tires I can fit on the front. Also, with a 5/8" spacer, and extended lugs, do the rears on the front cause any issues?
Gary Wells
White turbo Buick trailer park trash
Mar 2, 2002
8,198
223
63
long Beach, PRK.
Info on GTA wheels
Same manufacturer, but different manufacturing processes. 1 is a 1 piece design, and the other is a 2 piece design, dunno which is which.
justabuickv6
907
0
16
50
League City, Texas
Visit site
Here is what I have gathered. Ya'll help me fill in the blanks.
And please offer more if you know.
Pontiac GTA rim manufacturer: JWC
Manufacturer info:
GTA rims were available only in 16x8.
The Pontiac GTA’s came fitted with these rims from 87-92.
GTA 87-88 are the non-dimpled 1 piece design.
GTA 89-92 are the dimpled 2 piece design.
The GTA’s are marked “front” and “rear”.
Front offset:
Rear offset:
Buick GNX rim manufacturer: JWC
Manufacturer info:
GNX rims were available in 16x8.
Buick GNX came fitted with these rims in 1987.
The GNX are marked “OFF-15” for the fronts and “OFF-23” for the rears. Both front and rear also have the marking of “8JJX16”.
Front offset:
Rear offset:
Quick6'n'-K.C.
wana steal it? meet mr9mm
Staff member
Nov 24, 2001
8,840
23
38
43
under the hood of many turbo buicks.
Visit site
So you are wanting to run the 2 fronts in the rears, and the 2 rears in the front.
8UWITH6 did it on his t-type with a 7 1/16 spacer, stock lug studs, and a knurled down acorn style lug nut.
The wheels fit fine, no side to side rubbing unless the car was lowered in the weeds.
Send him a PM if you like or visit his webpage
ttypegtarims
BW
JRNYMNDAVID
MACSTURBOTA
Jun 25, 2006
150
0
0
CEDAR RAPIDS,IOWA 52402
Sorry,you Are Incorrect
Manufacturer info:
Front offset:
Rear offset:
Manufacturer info:
Front offset:
Rear offset:
DIMPLED ARE ONE PIECE / NON=DIMPLED ARE TWO PIECE.
I HAVE BOTH TYPES AND CAN SEND PHOTOS IF YOU NEED PROOF.;)
justabuickv6
907
0
16
50
League City, Texas
Visit site
I sure wish I could edit these post instead of having to do it all over again.
Updated
Manufacturer info:
GTA 86-88 are the non-dimpled 2 piece design.
GTA 89-92 are the dimpled 1 piece design.
Front offset:
Front backspacing: 4.75”
Rear offset
Rear backspacing: 5.25”
Notes: It has been stated that the dimpled style is more desirable. The reason GM made the dimpled style was because the non dimpled style center hub was weak and was prone to cracking. In addition, 4 fronts are more desirable due to the offset.
Manufacturer info:
All GNX rims were not dimpled and were a 2 piece design.
Front offset: 15mm
Front backspacing: 3 15/16”
Rear offset: 23mm
Rear backspacing: 3 9/16”
justabuickv6
907
0
16
50
League City, Texas
Visit site
Updated:
Pontiac GTA (Gran Turismo Americano) rim manufacturer: JWC
Manufacturer info:
The Pontiac GTA’s came fitted with these rims from 87-92 under the RPO code Y84. This option included the PW7 Diamond Spoke Wheels.
GTA 87 are the non-dimpled 2 piece design.
GTA 88-92 are the dimpled 1 piece design. In 88, the PW7 (GTA) rims had a design change. It has been stated that the dimpled style are more desirable. The reason GM made the dimpled style was because the non dimpled style center hub was weak and was prone to cracking.
Front offset:
Rear offset
Weight: 15 lbs with no center cap
Notes: In addition, 4 fronts are more desirable due to the offset. For those individuals that have the rears, most use the “fronts” in the rear and the “rears” in the front. A spacer may be needed in the rear.
Manufacturer info:
Front offset: 15mm
Rear offset: 23mm
Weight:
GNTurbo6
Aug 20, 2006
337
0
16
34
Amherst, MA
I thought I read in another thread that the non-dimpled wheels sometimes cracked if there was too much power put to the wheels. I've been looking for the dimpled ones but I don't really mind going with a 5/8" space and longer lugs.
justabuickv6
907
0
16
50
League City, Texas
Visit site
I welcome everyones comments and additions. As far as I know, this stuff has been documented very well. I am trying to piece it all together.
It will be a living document. Meaning I will update it as I continue to receive info.
Also, just since today, I have received some info but its contradicts what others are saying. I don't want to post anything until I can try to check it out.
If anyone knows of a great website where this has been discussed, please let me know.
Thanks Ormand and JR...David
justabuickv6
907
0
16
50
League City, Texas
Visit site
More info.
Manufacturer info:
The Pontiac GTA’s (RPO code Y84) came fitted with these rims from 87-92. The 16x8 diamond spoke wheels were RPO code PW7.
GTA 87 are the non-dimpled 2 piece design. Marking on the 87 wheel are on the spokes themselves and not the hub. You will see “8JJX16”, “OFF 00” (for the front) “HH”, “Japan”, “Mold4” and an “87” date.
GTA 88-92 are the dimpled 1 piece design. In 88, the PW7 (GTA) rims had a design change. It has been stated that the dimpled style are more desirable. The reason GM made the dimpled style was because the non dimpled style center hub was weak and was prone to cracking. Marking on the 88-92 wheel are on the hub and not the spokes. “Front Only”, “8JJX16”, “89”, “3.16”, “Japan”, and “UM”.
Front offset:
Rear offset
Manufacturer info:
Front offset: 15mm
Rear offset: 23mm
Weight:
toofastforyou
2FAST4U
May 25, 2001
4,526
124
63
Saint-Eustache, QC Canada.
Jwc...
Speaking of JWC wheels, I looked on the net for a website, but they don't seem to have one...I haven't been able to find anything whatsoever about them...strange, isn't it? Does someone know a little more about them?
Thanks,
Claude :redface:
justabuickv6
907
0
16
50
League City, Texas
Visit site
Update
Update
Pontiac GTA rim manufacturer: JWL (Japan Light Alloy Wheel)
Manufacturer info: JAWA | Objective
Front offset:
Rear offset
If you run 12" brakes in front, rears will actually fit better than ftonts, due to the 3/8" increase in track width per side of 12" brakes.
or
2: If you plan on having the front wheels narrowed, for drag racing or a big/little look, the "rears" will work better if narrowed than "fronts".
Buick GNX rim manufacturer: JWL (Japan Light Alloy Wheel)
Front offset: 15mm
Rear offset: 23mm
Top Bottom
