Info setting Crank and Cam sensor
Evaddave 87gn
Always learning...
Looking for any information on setting the crank and cam sensor up. Is their a tool for crank sensor? How far from blades do I place it? Basically how do you install a new one. Motor will be comming back from machine shop soon, so trying to gather anything I need to get it running. I plan on buying a cap for the cam sensor from caspers, and a new crank sensor aswell. Any help would be great !! :biggrin: :biggrin:
Dave :D
The crank sensor needs to be centered between the blades,The cam sensor,buying the cap and following the directions is a great idea,If not GNTYPE.org has the correct procedure
Is there an easy way to center it?
Is there any clearance issues? How do I know if I set it correctly before I start it?
Install it with the blade out of the way, turn it over with a socket and ratchet until the blade is in the center of the sensor, the loosen the pinch bolt and make sure the sensro is center on the blade
That caspers peice is nice,just set the crank at TDC and adjust it.That makes it pretty simple
Thanks for al the info
Thanks all who posted. Turns out that I forgot all about the Vortex site. Very good details on what needs done. Thanks Benched!
DAve
