Injectors at the Dyno???
qws2000
Well I had the car at the Dyno the other day and I was looking over the log. I happen to notice the Duty cycle of the Injectors, well at 4300 rpm's it read 39% and at the end the rpm's were 5725 and 82.7%. I was just wondering is that right??
I would not be comfortable with the DC reading 83% at 5725 RPM?
What is your voltage reading at that level and how old are the fuel pumps?
Similar builds we have tested have the DC in the mid-60's.
It would be nice to know where HP and torque peaked and other data as well.
What are you using to READ DC ???
80lb inj?
You must be making some decent HP! No?
Voltage was...?
Maybe try a voltage booster before considering swapping injectors or other ideas?
I don't want to really show you guys how little I know, but what does DC stand for... The volts were 14.4 and on that pull HP was 578 and TQ 541 at 30 psi..... The 4300 rpms was not WOT it was climbing upward...
80lb injectors and does have volt booster... Nick the pumps are 2yrs old Reds Double Pumper...
What 80# injectors ?? What are you logging the DC with ?? and whats your idle fuel pressure line off ?
The duty cycle is the time the injector is open over the available time the injector can be open for a given stroke. 100% duty cycle is 720 degrees of crank rotation. As the engine speed increases the available time for the injector to be open per duty cycle decreases, at the same time the engine fuel requirements increase as the airflow thru the engine increases. So it may make sense considering the large cam and turbo.
89, I got the injectors from Eric when I got his 5.7 chip, but now it is a 6.1. I have a power logger It is a sniper made in Fla... I think you are asking what is the fuel pressure at idle and it is 40/41...
Great ... you need to raise your base FP that's FIRST ... Those injectors like to operate at higher Fuel pressures.. you will see just adding in 5 psi what will happen to the DC.
Second what your seeing with the PL is slightly elevated from what the actual DC is ...
Those injectors aren't even close to being done @ that power level... so you have room left ( way more than what your making power wise now)
Also as mentioned above .. make sure you check voltage at the pumps to ensure that is not a problem
I have no issues with seeing 90% DC ...ON SIEMENS 80's others I can't comment about as it would depend on which injector...
YOU CAN NOT JUST SAY don't ever go above X % DC as its all relative to WHAT the injector linearity is as well as the pumps that are supplying the fuel. Further more the injector drivers themselves
have an impact.
The key to the puzzle is to match the pump, injectors, along with making sure clean power is supplied to each while balancing pressure to keep up with the power being made.
I have yet to ever see an injector FAIL @ 100 % duty cycle.. but what can happen is that the coil may over heat from extended FULL ON time.
The other thing is that running higher DC's on CERTAIN injectors will lead to irratic fuel delivery ... The Siemens don't exhibit this behavior until almost full Saturation. They also work EXTREMELY well at higher Fuel pressures...
Turn the pressure up.. see what happens to the DC !
Eric's chips are usually set up for 43lbs no line on at idle.
I don't think 14.4 Volts = Voltage-booster working...?
Using One on my car, I am over 15, or even 16 volts when it is activated.
14.4 sounds like normal Alt. output to me...?
Anyone else have a comment about that ?
80lb injectors, pump gas, alcohol.. should be in the 60's for DC. Unless FP is dropping or readings are wrong.
