injectors
Chuck Leeper
8/10's of a century!
Staff member
May 28, 2001
11,796
1,459
113
Madison, Ga.
Other than coming up 2 short, I don't know why not.;)
The LS system is operated at 58psi, {4 bar}. So, the 3 bar rated injs will have a higher pph.
What size are the v sicks injs?
Depending on how the LS fuel rails are spaced, you may have to change the rail mount height.
The various LS intakes will have different rail configs.
MAXSIX
http://i574.photobucket.c
i run Bosch 160lbs maybe just buying 2 more. i mesure the stock vs my 160lbs they have close lenght and same connector
Top Bottom
