installed 50 lber's and chip tonight
trbojo
'Stang Stinger
delphi injectors from racetronix, and chips from eric marshall. all i have to say is, throttle response is 200% better. mash it and the engine screams seamlessly. i really didn't have much test time, as it started to rain just as i took it out. went out and mashed it with a few sprinkles on the ground, and got sideways in a heartbeat with the drag radials. i am totally satisfied. hoping to post a low 12-high 11 slip soon. the install took 1 1/2 hours, but i am a tech with all the tools, and did it in the shop. thanks again to eric and racetronix!
took it out tonight and had some fun! 02's in the 750's at the 1/4 mile mark. no knock at 18 psi! gas mileage seems better. guess the rich o2 readings i was getting with the old injectors was due to one or more dumping fuel. can't wait to get to the track for some new times. turbo spool also seems alot faster. :D :D :D
What size injectors were you running before? Arn't 750's O2 a little lean?
had the stock 28lber's before. i was told mid to low 700's is fine as long as you're not getting knock. basically, lean it out as much as you can until you start to lose power.
