BLACKHAWK38
- May 26, 2002
NEW GN owner needs some help, installed the following on an entirely stock car
1 heated O2
2 RJC power plate
3 237 3 bar regulator(non adjustable)
4 racetronix 340 walbro with hot wire kit
5 Poston's 93 street chip
6 adjustable waste gate actuator end
7 running 100% Sunoco GT-100 unleaded
I got 113 blm with hot wire kit connected at idle
AND 120 BLM with straight factory fuel pump hot feed( hot wire not hook-ed up)
PROBLEM IS WOT 2-3 shift >>>>>> BIG COUGH boom bang OVER FUELING < OVERBOOST ?
BAR GRAPGH IS IN THE RED< NO MECHANICAL BOOST GAUGE
I should maybe enlarge orfice in waste gate Y hose from compressor to turn down boost???
I should lower fuel pump voltage untill in 10 lb or more boost?
Having fun with new toy!!!!!
Blackhawk38
1 heated O2
2 RJC power plate
Blackhawk38
